Okay, just got back from the dealer. Quick overview of what's happening and what's been done. For the past, oh, 6 months or so, the car has been randomly shutting down while driving. All electrical systems are working, as well as the starter. Eventually, after 5-15 tries, it starts (while setting in the middle of the road). So far, MAF, throttle position sensor, and vaccum lines have been fixed/replaced. The last time a "fix" was done, the car was symptom free for around 2-3 months. However, the symptoms are now back. The check engine light wasn't on until about 3 days into the latest problems. So, what the heck, I went to the dealer...
Apparently, my Secondary Air Pump is triggering the codes, and on inspection, looks like crap. The mechanic states that this could be causing the problems, but that might not be the only thing. Of note, I refuse to spend any more significant $$ on this car, so unless a cheap fix is made, this is goodbye. So, my questions to you are:
1) Does it sound plausible that the Secondary Air Pump can cause this problem?
2) I'm thinking of buying the part online and doing it myself, to save a potential $600+ from the dealer. Is this very difficult? And more importantly, the mechanic said after installing a new one, the computer, etc. will require resetting/readjusting <--is this true?
Thank you,
an unhappy VW owner
Thank you,
an unhappy VW owner
