I have a 2012 base Beetle with 63,000 miles with 2.5L with auto trans. When driving the service wrench will appear and the gear indicator on the dash will disappear. Does not always happen when driving and always resets when the vehicle is shut off. Anyone have snd idea what is causing the issue.
It’s not oil service related since I always reset it after every oil change.
It’s says it a service indicator but that’s it. I have ran a scan a. No codes show up. I did do some more research and it is possible the ECU needs updated.
That does seem to be geared to work with vw's. I haven't heard of a software update for this issue; you might contact your local vw dealer and see if there is a recall or update for your particular car.
