Where can I buy the bushings for the shifter cable on the shifter side. Is this a dealer only item?
Problem is one of the cables come loose from the shifter. It is stuck in 5th gear. The shifter moves front to back freely.
I do not have it taken apart from the bottom side yet but from top side I can see the cable is not connected to the shifter. It has a round hole on the end. From previous experience with other cars I would assume the bushing wore out and needs replaced.
In the link you provided in the third/last diagram it appears I need part #24.
Thanks for your help
Give a vw dealer a call; it might be available as a separate part or as a whole cable assembly.
You might try online vw parts places; like;
www.vwparts2go.com
www.1stvwparts.com
