BEAR
Well Omaha has gone to missing shifts. How do I know if I need a Trans Valve Body vs complete Trans? on a related note; Revmax sells what they call an updated Valve Body. Has anyone installed one of these "updated" versions in their NB? If so how does it perform?
09G TF60SN OEM Updated Valve Body 2003-2004
How many miles on the car? Assume you have a 6 speed due to the link provided?
Valve body is the primary suspect, they ALL fail between 60-90k miles depending on how much city driving the car sees.
Search my signature for more trans info and also see this post - http://newbeetle.org/forums/transmi...ilt-valve-body-replacement-my-experience.html
Almost all of the valve bodies will be "updated".
Also be curious what the warranty is on this valve body, many shops give 2 year unlimited mileage warranty on reworked valve bodies.
This is a DIY if you are reasonably handy, a bit more than an oil change, but not overly difficult if you pay attention.
BEAR
thanks for the reply. She has 88k miles so I guess its right in that range.
