Can anyone help me with my 2000 Bug, 2.0, with 97,000 miles. Not all the time but sometimes when i go out to start it up in morning it will start but i have a hard time getting into gear. i will press on the brake peddle and push in to move from P to R or D and it won't move. i will then turn the wheel all the way to left then all the way to the right and try again and it will work. Does the Steering wheel have anything to do with this? is their a brake solenoid that i should replace? i am at a lost and not sure what to do.
Discussion Starter #2
Shifting
not sure if this is a time thing or an electrical problem. if i press the brake peddle 7 or 8 times then i can shift into R or D. Does anyone know if there is a solenoid that is should replace? i have already replaced the brake switch under the peddle.
Any help would be appreciated
