TDIer
I have the atlas skidplate on my tdi, will the neuspeed front sway bar also fit?
Sent from my Desire HD using AutoGuide.Com Free
TDIer
Above. The "lower tie bars" are the one that don't fit. I ran an old school Evolution Imports skid plate and a Neuspeed front sway for years. The front sway bar fits in the stock location everywhere but the axle "hoops" which extend higher to accommodate a more extreme axle angle in lowered cars.
TDIer
Fantastic, cant wait to combine them then:D
Make sure you put in a beefy rear sway too. I put the front sway in first and got a pile of unwanted understeer. They're made to work as a set.
If you just want axle clearance just cut the OEM one out and forget about it. An aluminum skid plate stiffens up the front end enough that I can't even tell I'm running without one.
TDIer
Discussion Starter · #7 ·
The "plan" is to do both 25mm but i wanted to do the front first. I didnt even think that the skid plate would also help out. good info thx
