Based on a suggestion of a member, I have implemented a modification to the layout in which your "postbit" (that's the userinfo that appears above each of your posts) is dramatically reduced after your first post on a particular page. The first time you post on a page, you have full info. The second (and third, and so on) time, I only show your username and reputation.
I'm not sure I like this. It does reduce vertical space some, but I'm not sure the slight vertical space saving is worth the loss of information. So, I'm polling you guys. What do you think? Do you like it this way?
