My engine has been smelling of burning oil more so than before, today after drive for 15 minutes on the highway, about 6 minutes were 90mph (gotta get to class) my engine was smoking. The hood cover is a bit ripped and I don't know if the smoke is that burning or more oil burning. Oil IS a bit over filled (about half a centimeter over the good area). Coolant fluids are good.
Does the underhood engine cover burn? Should I take it off? I plan to also get an oil change tomorrow but I'm still kinda worried...
Valve cover gaskets and the oil cooler seal; are common areas that leak oil. You need to inspect the engine for the source of the leak or consider, getting a oil leak dye kit.
https://www.google.com/#q=oil+leak+dye+kit
Valve Cover Gasket Replaced- problem solved!
It turns out so far that after changing the valve cover gasket the engine has not smoked since :) Been driving now for a week.
Anyways I'm posting a new thread because now my engine overheats from a slow leak. I replaced the coolant flange at the same time as the valve cover gasket- I also used a cooling system cleaner to clean out the mess of green tinted coolant coming out (I hate when service places try to "top off" fluids they don't know about...
