I was replacing the purge valve on my 2000 Beetle and this hose snapped. It was attached under the hood right above the purge valve. Any ideas what it is and where it goes? How to replace? The second pic shows where it leaves the hood. Thank you!!!
washer fluid hose
Correct, looks just like the washer fluid hose they get old and brittle. I replaced mine 1-2 years ago when I had to remove the washer fluid reservoir to pull out the A/C lines out. I just used a high temperature hose of the same diameter, works like a champ.
