I've seemed to always have a bit of an issue with water since buying the car 2 years ago. It started off with a few leaks in the passenger seats coming from the roof, which i am pretty sure is coming from some blocked sunroof drains!
But i also have a soggy rear passenger footwell! I kept all windows open all last week whilst it was warm to try and dry it out, and I've been using socks filled with cat litter to try and draw the moisture out at night, but I've just gone to check on it again, and its still damp, even though it hasn't rained!!
Could this be the sunroof issue again, even though it hasn't rained?!
Any advice would be great!
Thanks!
I would get those drains cleared out. Water will go to the lowest point. So if you are getting water in through the clogged drains and that part of teh car is the lowest, that's where the water will end up.
Then do what you can with maybe a shop vac or something to get as much water out of the carpet as possible. Also, kitty litter isn't going to do much, IMO. Get yourself some containers of Damp Rid.
