This DIY is for Removing/Replacing the Stock Front Nose Sound Panels; aka Skid Plate. Actually only the Center Sound Panel can truly be called a skid plate.
DISCLAIMER: The author(s) assume that you (the reader) are reasonably capable with the automotive tools necessary to get the job accomplished, which means that you won’t glue your fingers together or use a cutting torch to get the bad part out and are smart enough to know not to try to blame or post ranting about anyone else if something goes horribly wrong ... AGREED?
These instructions were developed using the following NB...
1) 1998 AEG 2.0 Liter, 5 Speed, O2J Transmission
As always, just remember to offer a simple thank you and credit to the original author (D2Beetle) when you tell all of your BUG buddies!!
TIME NEEDED: 30 Minutes.
ITEMS NEEDED: An eBahn Bentley DVD or Haynes manual.
PROJECT COST: These parts are typically dealer parts, so the prices noted here are dealer prices ...
Drivers Side Panel: $ 82.88 (1C0 825 245E)
Passengers Side Panel: $ 51.19 (1C0 825 250C)
Center Sound Panel: $ 95.46 (1J0 825 237 AD) [Skid Plate]
... TN Taxes 9.75%: $ 22.38
... Parts Grand Total: $ 251.91
SPECIAL TOOLS: None.
WARNINGS: You have to jack up the car so take the necessary precautions for working under a car.
CAUTIONS: Be careful with all plastic, it will be brittle. If something does not move look for the screw(s) that you missed? There will be lots of screws so do not loose any, I put mine in Ziploc bag(s) labeled as to where they go.
So let’s begin ...
The Pic below shows you the general location of the Sound Panels. Drivers Side Red, Center Yellow and Passenger Side Orange.
So let’s begin ...
