I currently have PFR6Q plugs in my 2004 1.8 liter turbo. Gap is set at .031 per the service manual. I see numbers on here ranging from .028 to .032 that it is supposed to be set at. I installed 4 new coil packs last night. Trying to fix the cutout at high acceleration. Cuts out very bad. Also found oil around coil packs. Figure that is the valve cover gasket. Gonna order and replace those since that's a easy fix from blauparts. My question is this, which are better
NGK PFR6Q or FR7kpp33+ bosch plugs? Would the incorrect gap cause my issue? During normal everyday driving you have no issue. Hard acceleration or high speed and it cuts out almost feels like a limp mode. It throws the codes listed below.
Codes that are coming up.
p0411
p1297
p0304
Any and all help would be appreciated.
