Hi, I am new to the forum and looking for some expert instructions. I have a 2000 1.8 Litre Turbo Beetle. In the last month it has been giving me fits when it starts. It will turn over, but not engage for long. The more I attempt to turn it over the longer it stays on. Eventually it will run. Typically it takes 2 to 5 times to get it to stay running. The problem is getting worse. I bought the car used, and talking with a friend of mine who builds cars he thought it could be the spark plugs since it only does this when the car is cold. After I drive around even for five minutes it starts every time.
This is why I decided to attempt the spark plug replacement. However, I've run into a snafu. I've got the bolts removed which hold down the spark plugs. Where I am having trouble is disengaging the spark plug wires from the back of the casing so that I can lift out the spark plugs. If anyone has suggestions tips and can walk me through it I would be much appreciative. Thanks, Nicole.
