This thread should be helpful:
http://newbeetle.org/forums/questio...tle/77329-2001-beetle-broken-speedometer.html
not sure if there is an easier way but someone will come along and let you know.Occasionally, the plastic speedometer drive gear will break and fall off of the differential carrier and the speedometer will stop working. To repair this, the transmission must be removed and the differential disassembled far enough to replace the plastic gear.
