A while ago, I thought on occasion my 2k beetle would jump or slide over on a tight curve so I decided to check on it. I found that some how the bolt on the ball joint stud was loose allowing the ball joint stud to move around in the knuckle . Surprisingly I didn't have any odd tire wear or handling problems other than that odd occasional jumping /slide over. I've discovered that the ball joint stud hole on the knuckle is enlarged and I can no longer tighten the ball joint stud tight enough in the knuckle . Any solutions to this problem other than replacing the knuckle ?
TX. Eldoguy
