I have developed a power steering leak in my 02 1.8t. It seems to have just started and when I fill the reservoir it leaks out from the passengers side back by the steering rack-tie rod.
My questions are, how do you tell if a steering rack is bad and what would cause a leak on this side of the car? Also, would it just start leaking all of a sudden or could it possibly be a hose to the rack?
It leaks out fast and a lot, just trying to get some info before I crawl under to look at it after work. I did make sure the reservoir tank was not leaking and the hose to the pump was not leaking also.
One last question, how do I tell if I have Variable Ratio Steering(also called servotronic)
