I believe I have found a good solution: Ice Premium Care All-in-One Interior Cleaner and Protectant by Turtle Wax.
I tried a number of other products without luck. Rubbing alcohol/isopropyl alcohol helps, but is a lot of work and removes the soft touch. I found a moderate pre cleaning with the alcohol followed by the ice worked great for the non dash plastics. I only used the Ice on the dash and it appears to have worked. Note its not instantaneous, it takes several applications over a 30 day period. There is still a small amount of sticky, but its 90% better than before I used the Ice.
