I recently bought a 2001 Beetle 2.0L for my son and have been working on fixing the little things that are currently wrong with it. I just found the cable that works the defrost position switch broken and I am unable to move what is left of the cable. The other door that directs to the floor and mid-vents works fine and the temp door cable moves freely also. I need to know what may be involved in replacing that cable and where the door is located that is stuck or out of the snap bushings. All help and thoughts from you beetle guru's would be greatly appreciated.
On another note, the gas filler door does not open and I hear the switch in the drivers door panel actuate but the latch does not move to release the door. I was wondering how to get at the cable to check the connections. I have checked all the fuses and do not have any that are blown.
Thanks again, Bruce
Thanks again, Bruce
