1 - 11 of 11 Posts
I was passing another car the other day and the roof closed.
It was popped up and it just closed.
does this happen when the spoiler goes up?
Beetle Cup racer
You been speeding...!!!!! at over 88 the roof closes and in the process it pops your ears into oblivion....
(also it closes the windows, just in case..)
It happens at 91. It also gets stuck in the erect position if you are passing a semi with the pedal to the metal :D .The sunroof will stay open if it's opened the other way.
20V GTRS
I use mine to know when I am at a good cruzin speed, but that is normal operation for the sunroof to close to help with aerodynamics. I have also found that when having the sunroof poped up then manually openend the spoiler there is almost no windnoise when driving on the highway doing anythign from 50-70.
"Preparing for blast-off!" :D
It happened only one time with us. Ooops, going too fast! :eek:
Feel the Power!
imsos04 said:
I have an 04 NBC turbo. Do the windows close automatically at a certain speed on the vert too?:confused:
Nope... I've driven at 100+ with the top and windows down.
1 - 11 of 11 Posts
