2001 Beetle Sports Edition
Sensitive content, not recommended for those under 18 Show Content
252443
Does anyone knows where this switch goes? I found it unplugged when I got the car...
Discussion Starter · #2 ·
I'm still trying to figure out what the heck is this thing? Oh yeah. Newbie here
Maybe, the position sensor; for the hood latch? Did you look at a wiring diagram and match wire insulation colors?
I didn't look at the wiring diagram. But I did look at the switch. It somehow don't have a place for it.... My best guess is some part was removed.
Do you have vcds? If so you can go to the central convince module and see if the hood registers as being open or closed. You could even toggle that little switch and see if the hood position changes in vcds.
