Our 2000 Beetle had the timing belt replaced a couple of years ago by our local mechanic. He didn't have what it took to turn off the check engine light. We don't have a local VW dealership, and given that it was our teenager's car and never really left town, we never got around to taking it to a dealership in another location to get rid of the light. The car drove as smooth as could be.
In the last several weeks (before sending aforementioned teen off to college out of state), I ordered a scanner that was capable of turning off the check engine light. I turned it off and it came back on, and gave us fault code 17748 as the reason.
That code indicates the following problem: Camshaft/Crankshaft Position Sensors - Out of Sequence
We took the car to our local mechanic, and he checked everything out and said the engine, timing belt... all of it was exactly as it should be. The car wasn't having any issues at all when being driven. He said that apparently, one or the other sensor wasn't communicating properly - he didn't know which one - and that if it was driving okay it was up to us to decide whether or not we wanted to spend the $500ish to repace them. The downside of not doing so was that we couldn't get the check engine light to go off, so if a new, real problem arose, we wouldn't know it. Ultimately, we opted not to have him replace them at that time.
As we were taking our child off to college - which included taking the Beetle - it started having issues. When the gear is shifted into the next position, it didn't seem to want to pick up the new position. It was sluggish and it would take a bit of time for it to kick into the new gear. Initially it was just happening at higher speeds, but eventually it was behaving that way at lower speeds. When it was trying to keep up with a lead vehicle, it had trouble... but when I drove it and just eased into a higher rate of speed, I really didn't have too much of a problem.
Could this resistance to moving into the next gear be the result of the faulty Camshaft/Crankshaft Position Sensors? Or rather, them being out of sequence?
