Hello, can anyone tell me the proper procedure after you install a new throttle body, from what i'm seeing is that you can't just put a new one on and drive off, what has to to be done in this case?
Well, you could but you should have a Throttle body adaption done via a Vag com. Takes about 2 minutes tops and will calibrate your Throttle body to your ECM.
Other than that you should be good to go.
