1 - 11 of 11 Posts
Hey everyone I have a problem with my 99 new beetle tdi it has 272k on it and the injection pump was going bad so I replaced it with a used one that 170k on it and now it won't rev past 2800rpm and it idles nd runs very loud someone please help
Have you scanned for codes? Did you check timing? IQ? Where did you get the pump from?
Yea it has a quality adj reached upper limit and glow plug codes but they were already in it and no I haven't had it checked with vagcom.
And the replacement pump came off a good motor that sat for a while after it was took out of the car
What are the exact code numbers you're getting? What problems were you having that prompted you to replace the pump?
The pump I took off would idle but every 30 seconds It would rev up and miss on its own and hat run really bad and it was very hard cranking but it would run fine while on the highway at a higher rpm
The codes are. P1562. And. P0380
Discussion Starter · #8 ·
I haven't cleared them yet I talked to a shop and they think my timming is off so I'm going to recheck it when I can and I'll get back to u
1 - 11 of 11 Posts
