I have had my beetle for just about 2 months. 06 New Beetle Convertible. Well first I wanted to change the inside air cabin filter...kinda smelled funny, just not clean! A piece of cake, took me about 15 minutes. Started here then watched a youtube video. OMG was it ever dirty! Mold, Leaves, looked like a rats nest, couldn't see light thru it. Car smells great now! Next the window on passenger side rattled like crazy and was making me even crazier...Took off the inside panel, use a plastic tool to pry, don't worry, it wont break, just sounds like it. Removed the plugs and rolled the window down far enough to see adjustment screws for window, well the one on the right was so loose, I'm surprised my window didn't just fall off. Tightened screws, and yahoo, my sanity is back! Next and most annoying...The convertible roof. I would try to open, and like many others who have this problem, it would freeze about 80% done. Waited 5 or so minutes and it would finish the cycle. The lock on right arm would not lock shut. So after reading many hours of post I ordered the micro switch that fits under the hydraulic arm on right hand side. I took the seats out, and removed the inside panel, you have to adjust the roof up and down to get a good hold on the old part to remove. Well I had to give up on that and get my husband to do it, I just couldn't get it removed, He came to my rescue and did it in about 30 minutes. Yay, now the top goes thru the complete cycle, only one problem, the right latch still wouldn't lock down. I was so p'd off that I ordered a boot hoping it would keep it in place while driving (luckily no alarms were going off) I was getting ready to button everything back up and just live with it, then my husband volunteered to look at it one more time for me. He is my HERO! It was a loose spring on the emergency handle of the locking arm. It wouldn't lock in place to Lock the arm down. Next project is the driver door latch actuator, door doesn't drop that extra inch to clear top and it is has frayed the top material. I glued the top today in that spot with Alleens fabric glue from Walmart, so far so good. I've ordered a turn signal stalk because of the annoying ticking even after the blinkers are turned off. I'm leaving that one to a mechanic since the air bag is involved. There is a youtube video on how to, but I'm not comfortable trying that one, well plus my husband said NO! I'm a 50 year old Grandma, very stubborn and determined to do things myself, and have been able to do most of this by myself with the help of this forum. No scan tool involved...Some may say I'm crazy for that, but all the advice I received here worked. THANK YOU!
I'm so glad you joined us, and you found some helpful things here. That's what we're here for! :party:
