This is a question for all the NB audio junkies out there:
what part of the trunk did you attach your amp ground wire??
I wanna know where it will be the easiest to install this wire from the amp… I want the most solid, cleanest grounding point without doing any cutting, drilling and/or sanding as much as possible.. due tot he fact that the gas tank is back there and I might end up drilling thru the tank or much worse setting by baby up on fire.
Appreciate all the help. Thanks guys
PS least amount of work, as I don't have a handheld sander at home.. im thinking the seatbelt mount points for the rear seats but im on here to get other opinions
