21 - 23 of 23 Posts
Fixing electrical issues is usually a matter of checking and rechecking not necessarily back breaking work but often frustrating. Sometimes a wire can be corroded and causing intermittent problems and even after taking the connector apart it’s not readily visible.
Discussion Starter #22
I took the upper dash apart, even though there was critter nest in there, no evidence of chewed or exposed wires. I read another forum entry, from someone who was having the same problem as I am having, That the ECM was bad (Cant set throttle, code comes back right after clearing) Also I read that a 1998-99 ECM will work but does not have the immobilizer, (No need for programming, just a blinking security light) I am really tempted in getting one from a local salvage yard.
21 - 23 of 23 Posts
