Interesting, when you said 205 I thought, well that is odd. My coolant temp was reading 80 Celsius which can't be that hot.
So I looked it up and according to what I read the TDI should be about 190 F, which is 87.78 C.
So time to change the thermostat again. Seems like these need to be replaced every 5 years.
Be careful, what you are quoting of 190F/87C is the thermostat operating temperature, not the engine coolant temperature.
One most all cars and trunks the engine coolant sensor is located at the cylinder head water return to the radiator. So the temperature sensor is usually measuring coolant temps that are 15-20F higher than the actual thermostat operating temperature. So again, I would expect the engine temp to actually read 205-210F at the sensor at warm idle.
I do not have any baseline numbers on the TDI, however, it is likely in the range I am stating.
Cool running engines run richer, get far worse fuel economy, have issues with premature crankcase contamination.
You might see if anyone in the TDI section can confirm their engine operating temperatures.
Also I find that thermostats may fail as early as 2 years, so you really need to baseline your engine temp and then keep an eye on it with a scan tool every few months.
Let me know what you find for the final expected baseline warm idle coolant temp.
