Hey all,
Replaced the throttle body on my 2000 NB 2.0L this afternoon. The old one was unable to be adapted using VAG-COM (see http://newbeetle.org/forums/2-0-liter-gas/49932-c-compressor-wont-kick.html) even after a thorough cleaning.
Cleaned the replacement throttle body, one I picked up from the local pick-and-pull off of a '98 NB 2.0L with Cruise. Now the new throttle body was able to be adapted successfully using VAG-COM but is making a horrible squeal at idle through about 2K RPM. I also got misfires on cylinders 1 and 3, which had never happened before.
I have another throttle body that I picked up off of eBay, but I was hoping to be able to use this junkyard one as it was $70 cheaper.
I'd love to hear any suggestions, but otherwise will swap the TB back and see if that at least eliminates the squealing/misfiring. Won't get around to this until later tonight. If the old TB doesn't squeal/misfire, I'll swap it out for the one I picked up on eBay...hopefully ONE of these THREE TBs will work! :p
