Hello- 1.8T NB- Finishing up a timing belt job with new tensioner water pump etc. Should any bolts get Locktite (red, blue?) before I button everything up? Cause I didn't use any Locktite. I'm not 100% buttoned up, but pretty close. Guess I could back up and add some if I really should. I've torqued my bolts to spec. I didnt see any reference to using it in my Haynes, but they were kinda vague on a few things...Dave
Whenever, I do a timing belt job on a 1.8T; I just try to replace the thread locker/loctite, on fasteners that I have seen had it on them to begin with from the factory. I use a torque wrench; on the hydraulic tensioner, waterpump and crank/harmonic balancer pulley. I put loctite on the timing belt tin cover bolts, crank/harmonic balancer bolts and leave the rest alone, just torquing to factory specs. I use the blauparts timing belt kits and they always come with a small amount of thread locker, it is the blue colored strength version.
locktite
Billy- thanks for the note. yeah i didn't really notice any residual thread locker on any of the bolts as I removed them, maybe thats why I didn't think to add any on reassembly. I could easily take the lower and middle metal covers off, add a drip to each and replace. I haven't put the crank pulley on yet. Dave
I think; there maybe some on there from vw; as vibration could be a issue? I have heard of crank pulleys; falling off, as people didn't tighten them down to spec. I figure; it is a nice additional precaution, against any possible problems and gives me peace of mind. Although, I think if you torque everything to factory spec; you probably will be fine, I guess it makes me feel better, to have thread locker on those areas.
As far as I can tell; the crank bolts, are not torque to yield and I have reused them without any problems.
Crankshaft Pulley Bolt: M8x16
Volkswagen Part #: N10303607
https://www.ecstuning.com/Search/SiteSearch/Crankshaft_Pulley_Bolt/ES6012/
Now on the engine mounts; those ARE torque to yield and if you don't replace them, it is easy to strip out the mounting threads (they are aluminum). From my experience and research; I think the threads, may get distorted, when they stretch and will the aluminum being so soft, they are easy to strip. For tightening the motor mounts; tighten by hand and use a torque wrench. They are supposed to be replaced; one time use, torque to yield fasteners.
Stretch bolts for all Mk4 Golf/Jetta/New Beetle left or right engine mounts. This kit is good for ONE mount, either the left or right side.
Bolts Included:
N90596906 x 2 - Bolt M10x55x32
N10209605 x 2 - Bolt M12x1.5x65
Stretch_Mk4_Mounts Motor Mount Stretch Bolts - Left/Right, Mk4
In my case; I had removed the engine mounts, a number of times and didn't replace the torque to yield bolts, I ended up stripping out the mount bracket. I went ahead and put Time sert metal threaded inserts in them. These are pretty expensive but I figured; even if I bought a new bracket, it would end up stripping out again, anyway. So, that was a permanent and professional repair solution; hopefully, I'll never have to deal with it, ever again. So, NOT replacing the torque to yield motor mount bolts, tightening/torqueing by hand; can end up destroying the threads and require expesive thread repairs as a result.
http://newbeetle.org/forums/transmission-talk/50942-turbo-s-just-lost-1st-2nd-my-02m-6-speed-5.html
Notorious DOM
Awwwwww....Nurtz! I didn't. Well, that's what I get for being a VW n00b!
Maybe if it rattles apart, that'll give me an excuse to tell the wife, "Honey, I need a new, built, 1.8t. It'll only be a few thousand...
Well, under 10.
locktite
Well I pulled those cover bolts and used some blue on them. AND installed my crank pulley with blue (to spec torque). PROUDLY painted my mileage on the top TB cover. I made the 45 minute one way trip yesterday to my local dealer and bought those 4 engine mount bolts, so i'm good there, torqued them to 40nm plus 90.
I did notice tonight that there is a bunch of plastic rattling around inside the coolant globe. Looks like a little cone shaped thing that attaches to that 1/4" top port has disintegrated. Thinking about going to the junkyard to see if there is anything better. Would it be bad to just put that thing back in there? Dave
Hmm, maybe make a video or take a picture; of the problem in the globe you are referring to. A new coolant tank/globe; is not that expensive, so you might just go that route. You can get a genuine VW part; for $20-$30. At that price, it is hardly worth the hassle of going to the junkyard for a used one; which maybe brittle and failure prone from too many heat cycles and age.
Engine Coolant Expansion Tank. Reservoir.
Volkswagen Part Number: 1J0121407F
https://www.google.com/search?q=1J0...=chrome..69i57j69i60&sourceid=chrome&ie=UTF-8
https://www.google.com/search?q=vw+...rome..69i57.5183j0j7&sourceid=chrome&ie=UTF-8
Note: for future reference; the better timing belt kits, come with the needed stretch bolts (e.g. blauparts.com).
Discussion Starter · #8 ·
locktite
Wow, yeah, like 25-30$ I would never have believed that. I'll just buy a new one. I was expecting over 100.
