I am working on an '00 Beetle 1.8 for a friend. She was driving and the motor mount bolts broke. Engine dropped and she stopped the car. Had it towed to my place.
I replaced the mount and bolts, the oil pan, and repaired the exhaust flexpipe.
Started it today. When it runs (neutral) and is brought to 3000rpm, the timing area is very noisy. I removed the upper cover and found that at 3k rpm, the timing belt resonates, appears to have slack between the cam pulley and water pump. It looks like the belt moves up and down 1/4" over that 6" span.
Is this an indication that the tensioner is bad or just out of adjustment. I haven't pulled the lower cover or anything else. Just got it started today.
Any thoughts are appreciated.
Steve
Steve
