still haven't replacled my michelins...
anyway, would a 205/50-17 or 215/45-17 tire handle better than the stock 225/45-17? it seems to me that there's too much bulge on the 225/45's which would make it not handle as good. i'd like to maximize the handling when i do buy the new tires very soon.
does anyone have any experience with a "smaller" sized tire on a NB? thanx...
205/50 17 -VS- OEM 225/45 17
Pros
Better snow traction
Better High speed stability in rain
Better Fuel economy due to lower wind resistance and lower frictional losses
Quicker turn in response
Cons
Lower Cornering G's
Lower Grip in the dry
Less rim protection from curbs and automatic car washes
215/45 17 -VS- OEM 225/45 17
Pros
Lower overall gearing for better acceleration
Better stability in the rain
Cons
Speedometer error
less rim protection from potholes and curbs
rougher ride
lower cornering G's in the dry
lower gas milage due to lower gearing
higher cost due to less common size.
less tire choices
My recomendation is to stick with 225/45 17 for summer and all season use and use the 205/50 17 for winter tires.:goodjob:
Performance Freak
Second that, I run that exact setup, 225/45 summer, 205/50 winter on stock 17s.
The 225s on stock wheels work very well. You could extract maybe a little more performance mounting them to an 8" or even 8.5" wide rim, but it may not be quantifiable.
since i'm only using all-season tires, i guess i can stick with the 225's...just wanted to make sure before i order today...i can feel the snow coming. now if i could only decide which tires for sure :confused:
how do you like your proxes4's?
My advice is to goto www.tirerack.com and use thier excellant customer reviews, test data and comparison charts to help you make an educated decision. :goodjob:
i've done it a thousand times. i had it narrowed down to the Avon's or Kumho's & i just ordered the Kumho's after extensive research.
i still can't believe the Avon's are that highly rated especially when tirerack is the only place selling them...anyway, that, the price, & warranty is what sold me on the Kumho's...
thanx for all the help...looking forward to FINALLY having some nice tires on this beast ;)
I'm assuming you are reffering to the Kumho ASX?
If so... congrats it sounds like a great tire. :)
Discussion Starter · #8 ·
yep, that's the one!
