Hi Forum,
Newbie question, I have a 2002 1.8T with the Monsoon system. It sounds horrible, I was going to simply replace the headunit and speakers, but as I read, I don't think it's that simple. Can I just upgrade the speakers and keep the Monsoon head, or should I replace the headunit and power the speakers off that unit bypassing the OEM? Trying the find the most cost effective solution to what I thought was a simple problem. Thank you for any input/suggestions.
I thought my speakers were awful too and was contemplating changing it all. Monsoon as well in a 2004 convertible.
I replaced the head unit and it now sounds fantastic without having changed the speakers
1964 Deluxe, 2005 GLS 2014 Rline
Everything is replaceable. Don’t forget the monsoon has an amp in the trunk
Ok, I replaced the dash and rear speakers, along with the headunit. I wired the dash speakers directly to the headunit, the rear speakers are attached via the harness, now I have no rear speakers. I thinking of bypassing the Monsoon completely and run the rear speakers off the headunit as well.
Can I use the blue wire to power the antenna also be used to power the OEM amp? what color is that wire? Thanks.
