2008 SE with a newly stretched top to seal the back window. This was done by a shop as the top of the window glass was couple of inches from the top material. It holds, and water tested just fine. Did a hose test and found water getting in from along the right and left side where the top meets the body. Is this repairable DIY? or is it something that will get fixed when the top is replaced. Getting the budget for the new top, but can I keep it water-tight until then?
I searched for other posts with a leak in this spot, but see nothing. Hoping to get a few months, but also hoping for an honest opinion.
Its supposed to collect water there. I believe there is a drain in that area and a little flap that directs the water into the drain on the inside of the top
