The driver's door is sagging 1/4", probably from having to have the door taken apart and the check bar rewelded to the door and behind the A pillar.
I'd like to drop the striker plate down 1/4" on the B pillar (if I can find someone locally with a triple square 8mm bit, or if Amazon comes through by the weekend).
What are the final torque specifications for the two bolts that hold the striker plate to the B pillar?
Thanks
Thanks
I'd have thought it would have been more, like using a 6' Breaker Bar! I'd have probably over tightened it!
