So I am in the middle of replacing the timing belt (02' 2.0L), and in the process I've run across these four supposed Torque To Yield (TTY) bolts on the engine mount. What I can't find out, though, is if the three bolts that hold the lower part of the mount to the engine block are also TTY bolts. I don't want to find out later and then have to drop the motor again to replace them...or worse have them shear off!
So I took a trip to the local VW dealer to see if I could get some answers. They were not able to tell me for certain if the bolts were replaced or not during timing belt changes...but then told me they don't even carry the bolts in stock! That suggests that they likely never replace these bolts at all.
Since it looks like I can't even get my hands on these bolts in the near term, I have two options: 1) replace w/original bolts or 2) locate conventional grade 10.9 bolts. In either case, it's probably wise to drop the torque/angle specs and rely on some standard torque values for particular size/grade fasteners?
