The VCDS code on my 2004 NB 1.8L GLS turbo shows :
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Control Module Part Number: 1C0 907 379 M
Component and/or Version: ESP FRONT MK60 0102
Software Coding: 0019970
Work Shop Code: WSC 00028 000 00000
VCID: xxxxx
1 Fault Found:
00778 - Steering Angle Sensor (G85)
003 - Mechanical Failure
The Traction Control Warning light in on !
I tried to rest the steering wheel angle with : Options >Test >Apply >Select >03-ABS Brakes >Security Access >40168 > ”Not supported by Control Module” !!! Why ?
How can I get rid of that light ? Please help.
You may have to replace the clock spring/steering angle sensor. It’s all one unit under the steering wheel.
Did something happen to cause this, a little background would help.
