P0638 Volkswagen Throttle Actuator Control Range/Performance OBDII Engine Light Trouble Code | Engine-Codes.com
The throttle pedal assembly; was replaced? Used or new part? A hard reset; after the throttle replacement, might be a good idea.
In the above new trouble code; they are mentioning cleaning and adapting the throttle body, have you tried that?
You scanner; seems to be VW compatible but your saying, it won't work in "vw mode"? Maybe look for a update; on their website or contact their tech support? As with many of these Chinese scan tools; you milage may vary and they don't always work as advertised.
Super Memo Scanner for VAG AND CAN-OBD2 >>
Product Name: Super Memo Scanner for VAG AND CAN-OBD2
Part No.: U585
Net Weight: 0.8KG
1.1 Tool Description
1.LCD Display , 128*64 pixel display with contrast adjustment, Backlit
2.enter key selects displayed
3.exit key go back to the previous screens
4.up/down arrows-moves the selection pointer and scrolls up or down.
5.LEFT/RIGHT arrows-Select responses and moves cursor.
6.OBDII connector cable, connect car and the scan tool
7.Battery compartment
1.2 Product Specifications
• Display-Backlit LCD,128*64 pixel display.
• Operating Temperature- 0 to 50
• Internal Power- 9v Cell
• External Power: 10.0 to 15.5 vols provided via vehicle battery
• Update by internet
Dimensions:
• 195mm Length 81mm Width 32mm Height
• OBDII connector , 1500mm
1.3 Product Features
1.Works on all 1996 and newer cars & light trucks that are OBD II compliant (including the VPW, PWM, ISO, KWP 2000 and CAN protocols)
Reads and clears generic and manufacturer specific Diagnostic Trouble Codes (DTCs)
trouble codes display on the LCD, needn't the code book.
Scanning live data
Reading Freeze Frame Data
Testing I/M Reading Status
Reading vehicle info
Rescanning Data
2.works all VW, AUDI, SKODA, and SEAT vehicles. it can nearly do the same work as that of a VAG1551/1552. Available Functions:
Control Unit Information
Read Fault Codes
Measuring Blocks
Clear Fault Codes
Basic Setting
Adaptation
Single Reading
Output Tests
Code Module
Login
Service Oil Reset
Code Modes
Dealership Code Set
support the following systems:
Engine
Transmission
Airbag, etc.
there are 78 systems available.
VEHICLE COVERAGE:
• GM '96 - Current Year (OBD-II)
• Ford '96 - Current Year (OBD-II)
• Chrysler '96 - Current Year (OBD-II)
• Toyota '96 - Current Year (OBD-II)
• Honda '96 - Current Year (OBD-II)
• NISSAN '96 - Current Year (OBD-II)
• All other Asian and European '96 - Current Year (OBD-II)
• All new CAN protocol cars.
• All VW/AUDI cars.
They are listing; a downloadable software update from 2002, version 5.1; on their site here:
Memoscan.cn
Their tech support is listed as:
Contact Us
Company:MemoScan Technology Co., Ltd.
EMAIL:
[email protected]
It looks like; they have a newer version the VAG505:
Memoscan.cn
