Ok so I took my wife's 2001 GLX manual transmission out to replace the clutch with a clutch and lightweight flywheel from ECS Tuning, everything went fairly smoothly until I tried to get the transmission back on, Im doing it by myself and I found it impossible to get the transmission to go completely on and to get the input shaft to go in straight, I did use an alignment tool for the clutch and pressure plate. I've been wrestling with the transmission for a two days now and I'm getting frustrated. I have tried lowering and raising the engine and man handling the transmission but no luck so far. If anyone has done this job before and can give me some advice I will greatly appreciate it. Thank you in advance.
