1 - 9 of 9 Posts
I tried replacing the sensor with used ones out of another trans. Guess I'll get some new ones just don't want to waste money
252936
So, you replaced the sensors; no more trouble codes and everything is shifting well now? You, might want to reset; the kick down settings and that way, it can relearn with the trans/sensors, working as it should! I did that procedures; after a bad shifter assembly replacement and it really helped allot!
1 - 9 of 9 Posts
