In what place I find the TT Vents and the how to install??
You use a How To for install this mod?SMG said:I had a disaster with these vents.
They will never look stock.
The center console vent holes are bigger, as well as a different shape as the TT ones.
You can always see sort of down the hole, it's awful.
I do not reccommend this mod to anyone!
SMG
Translation a'la Babelfish...with a little creative license from me.
Labels on pictures:
luftaustritt - air outlet
erhebung - collection
gummi-klemme - rubber wedges (I was hoping they would have been candy... )
ein loch - a hole
zahnräder - gear wheels
luftklappe - choke (vent louver)
Guidance for the installation of the TT air duct.
With a screwdriver carefully apply pressure to the edge of the nozzle 2-3cm deep. Then one levers carefully the old nozzle forward, until you can raise her with the hand. It is not bolted on! One can raise in such a way.
This Pfalz (wall?) you must file or cut. I made mine with a Demmel, it went super. Caution! Do not slip. You do not want to hurt your Beetle nevertheless.
So it should look like this. Without barrier! Carefully cut off the top two rubber wedges with a carpet measurer (utility knife?).
On the TT nozzle you do not have completely to saw-away anything; it should fit it purely.
Pay attention that the choke in the vent is closed, and that the gear wheels on the nozzle are also in the closed position.
Do not damage the hole at the top of the nozzle.
I'm sure someone with more fluency in German can fix any of my minor mistakes...but this should be at least a good starting point. Watch someone already have done a translation in the time it took me to get this post put together!
I love your painted veritcal dash... Can i ask where you did that at or if you bought if offline?![]()
I like mine - the centers are a little odd, but wrapped in carbon fiber and custom made tubes to sync up with the oem connection made them fully functional! Works with what I was trying with the interior.
I didn't want to do the TT vents unless I could do the centers and even then I wanted the controls to work so I could shut them on or off.
