2000 vw beetle 1.8t
Turbo is my cars name because all u hear is the turbo going crazy at all times ok I've got another question would a bad driver side wheel hub and bearing make it seem like your clutch is slipping the car doesn't wanna move off the line at all you give it gas it barely moves but when you let off the gas it jumps forward I don't get it when it's cold it runs right
I’m not sure exactly what you’re describing but it sounds like you may have a boost hose that’s not attached properly. I would check all the boost pipes especially down underneath the passage side behind the front wheel well.
I bad hub/wheel bearing needs to be fixed, in extreme neglect situations a wheel can fall off.
