Our 2009 New Beetle with advanced air bags has problems with the turn signals and hazard lights. Signals stay on when switch is activated for both directions, hazard lights illuminate but will not flash. I'm suspecting the flasher unit is defective. Hazard switch is located above the radio in the center dash area. Is the flasher relay part of the switch? How do I gain access to the switch to remove it if the switch and relay are the same. thanks
