My 2004 Turbo s beetle has had many problems in the past 2years. It would randomly be dead when I went out to start it. The check engine light was my friend on my dash for the past 4-7months. It also had many other things replaced and I've spent nearly $2500 on it in 2 years NOT including normal wear/tear items like the tires and brakes.
Last week I drove to work only to arrive with my car smoking and giving me every dash warning light imaginable. I put some extra coolant in it and some oil and tried to drive it home. It made it, but it was smoking like a fire and leaking coolant. I towed it to my mechanic. He replaced a coolant pipe and a bypass coolant tube and said it was fixed. I take it home and once again she is smoking and leaking coolant. He tows it back to his shop. After 2-4days he finds out the radiator fans are not kicking on. He spends another 3-4days trying to figure out WHY they were not turning on after 10-15min of the engine running (thus only causing it to overheat when I was driving it for 10+min) He determined it was a short in the electrical wiring, but that he just couldn't figure out where. He told me to take it to a VW dealer. I get to to the VW dealer and they give me many things wrong:
1)Thermostat needs replaced
2)Water pump and timing belt need replaced
3)Radiator fans need replaced
4)Under hood fuse box needs replaced
I call my mechanic and talk to him. VW wants nearly $4k to fix these tings. My mechanic says that I don't need a thermostat or timing belt as I replaced those last year. Also he checked my water pump TWICE and he knows that is not a problem. He suggested getting JUST the underhood fuse box replaced and see if that fixes most the things. I just dove it home from the VW dealer and it is runnining well. It is not overheating and to top it off my AC kicked on when I started the car my AC has not worked in 2 YEARS! Is it really that simple? A underhood fuse box replacement was the cause of all these other repairs???!!!
The BAD/WORSE news is after this week long headache I went out and bought a new/used Honda Element. I'm at the tiem in my life I do need something bigger than my beetle and I need something reliable that I don't have to spend $500 on it every 2-5months
The fuse box; has MANY things connected to it, it is possible that was causing quite a few of the problems you described. If the fuse box was melted; you might want to have the electrical system checked for what was causing the wires to heat up and melt the fuse box (common problems: worn out cooling fans, wiring to the starter causing too much resistance, other components worn, causing too much draw/heating up the wiring)We all love our New Beetles; as they age, they will need more attention and repairs. Thats the first Pink Turbo S I have seen; must be a repaint? :)
Oh yes, I got it repainted 2-3months after I bought it.
Ali's Dad
Pink Bug - I live near St Louis ( I work there but live in Southern Il) - I have become quite skilled at Bug repairs maintaining my daughters 03 NBC 1.8Turbo. I 'fixed' the melting fuse box over a year ago and haven't had any issues since then (at least not with the fuse box!):) - I did just replace the alternator (along with the serpentine belt) and the disintegrating washer fluid line. I went through 5 fuse boxes and associated wire harnesses before fixing it permanently. I ordered a new wire (heavier gauge) that connects the alternator to the fuse box. I had to make a new connector for one end but the total job was less than $20.00.:):) If you haven't sent the bug packing I would be happy to check it out and give you some free advice. I have maintained this one for over two years, replaced both front axles, rebuilt the rear window lifts, replaced the alternator, spark plugs, secondary air pump, a bunch of vacuum lines and one way valves, still finding things to 'repair' almost daily as the PO failed to do even the most basic maintenance.
too cute
Very cute looking bug and owner congrats. You might have a bad fan control module or the fans themselves or both. I had the same problem two weeks ago I had to remove both fans, rebuilt and put back I also replaced the fan control module. Just replacing the fuse box is a temporary fix and the problem will come back later. Good luck.
