1 - 11 of 11 Posts
well finally finished , well almost. still have to color sand . and put the inner fender wells back on. in case you did not see the previos pics i added them :)
I love that you resurrected this now beautiful New Beetle. Thank you! :)
I like your frame machine!
Wrap a fresh blade like this with about three rounds of tape, drag it lightly over the runs. Kind of like when you are spreading body filler. Eventually it will knock them down flat, if you try to sand them out you will have a big problems. :)
Sent from AutoGuide.com App
so .. ? drag across holding the blade straight above not laying the blade down? do i have to completly knock the run all the way down before color sanding? and thank you for the help and everyone for the compliments :)
Hold it at about a 45 degree angle, and drag it towards you. It may take many strokes depending on the size of the run, but it will shave it down a little at a time.
Hit it with some 2000, then 3000 grit, then buff it out!
Worry less, drive more
Beautiful job!:cool:
Everett Street in May
Nice resurrection sir!! Glad to see a Beetle heading for the junk yard get a second chance and a good home.
:bigthumb:
1 - 11 of 11 Posts
