Where is the vac hose to the brake booster that if leaking or broke will cause the brake pedal not to work properly?
directly behind where you pour in your brake fluid youll feel it if its loose and in my case i could see it with a fklashlight shining back there toward the firewall
The vacuum hose you are looking for is number 12 in this diagram:
It should fit through the grommet (11) into the brake booster. Follow the hose back to the engine and look for where it is cracked or disconnected.
