Hello all, I have a 2001 GLX New Beetle with a 1.8T engine. I have been through a bunch of crap since I took this thing on as a basket case project, but have mostly been able to figure everything out and get it running well. Recently, I have been hearing noise after the vehicle is shut off that does not go away regardless of how long it sits. I pulled the fuse for the secondary cooling pump, which makes it stop, but the noise continues until I pull the battery.
I jacked up the vehicle and tracked the noise down to the vacuum pump. The pump itself seems to work properly, but it seems like the relay that controls it is sticking.
Where is the location of the relay that controls the vacuum pump located? I think there is a block under the dashboard, but I haven't seen it since the interior was reassembled. Any help would be much appreciated.
