1 - 16 of 16 Posts
Vag-Com Locator, Steve-Hall List, Codes, CEL codes, vagcom, l
I spent several hours trying to search for all this Info with tons of search words and after all the frustration, I put these links together in one searchable thread... This can be found easily now. Hope this helps others.
(If I'm outta line in doing this... please LMK.)
http://newbeetle.org/forums/technical-how/533-vag-com-sharing-thread.html
Steve-Hall Vag-Com list
http://vagcomlocator.com/tinc?key=cSZEvUVt&formname=VAGCOM
Frappr Map
http://www.frappr.com/vagcomlocator
Auto & Truck Electronics Tool Locator
VAG Tool Locator
Ross-Tech CEL Codes
Category:Fault Codes - Ross-Tech Wiki
Lenny's Volkswagon codes List
LENNYS VOLKSWAGEN-THE VW REPAIR AND PARTS SPECIALISTS
Bentley Publication Codes list
VW Online Technical Library - Diagnostic Trouble Codes (DTC) Tables
Source to Buy a Vag-Com
Ross-Tech: Home
Thanks Guys
Thanks Guys, I just had such a time searching the forums combined with a sketchy internet connection that I thought it might help others as well.
To All,
If there are other Important or Frequently Visited Links that I am not yet familiar with, please group them together and add them to this thread so we can try to keep this a Links Only thread as much as possible. :)
Good-bye Curby...
Awesome awesome awesome! Thanks for putting this together. ;)
Thank You
Thank you for taking the time to find all this info and sharing
I have an old Geniscan GS200 VW/AUDI Code Reader and this code 17704 Cooling system malfunction
was not in the user's manual thanks to you maybe I can get some help now.
Third Party Vag-Com
I bought a cheap reader off of eBay and downloaded the free software off of Ross-Tech's website and am going to try my hand at diagnosing this cooling system malfunction code (2181).
I thought replacing the non-functioning fan was going to solve the problem. Maybe it reset or maybe disconnecting the battery didn't clear it properly.
Vag-Com
Now I'm thinkin' I should buy a VAG-Com BEFORE i buy my Beetle ... so I can pull the codes BEFORE i buy. Anyone else do this? Thanks, George!
Right now I'm thinking a $349 Enthusiast model.
Who is John Galt?
Is it just me or are most of these links dead?
Vag-com owner near Houston, tx
I need to find a vag-com owner that would see why my CEL is on. I am near SW Houston. do not want to take to vw stealers. Have 2003 vw beetle.
I just got my vag-com (now called VCDS) in the mail yesterday, and lucky for you I'm in Tomball, TX. I'm waiting on a Bentley manual for 1998-2010 New beetles which should be here before Friday. PM me.
Cheap working cable and VAG-COM
Hello all,
Wasn't sure where to post this, but thought I'd let everyone know that this cable/software bundle worked fantastic for me.
http://www.amazon.com/gp/product/B002WIN8VQ/ref=cm_cr_mts_prod_img
This is CONFIRMED working to read/erase codes on a 99 Beetle, using an old laptop running XP service pack 3.
As any google search will tell you, DO NOT attempt to hook this cable or any other cable up to a VW that has an aftermarket radio, without testing the DLC (data link connector) with a volt meter FIRST. High probability you'll fry the scanner/cable.
Plenty of info about this at http://www.ross-tech.com/vag-com/aftermarket-radio.html.
Also, in order to use this cable, you must have some knowledge as to how to assign COM ports on your computer. The cable and VAG-COM will ONLY work together if the PC reads the cable from COM 1, COM 2, COM 3, OR COM 4....AND VAG-COM is set to look at the matching port for the cable.
Again, I haven't been able to try any other functions with the included VAG-COM 409.1 software, but I was successful in reading ABS/AIRBAG/ENGINE codes and deleting them with everything included in that link.
Hope this helps someone else out.
vag-com
Anybody in the Houston area that knows how to recode or perform adaptation a new ABS module with the vagcom ?
I removed the sticky due to most of the links being dead. A new post has been created and made sticky.
1 - 16 of 16 Posts
