So, I got my Vag-Com about a week ago and I'm scanning my car, btw which a 1.8TS, and I get a good test connection through my COM port and every time I try to run the codes I get a message "No Response from controller." Is this because I'm not making good contact at the connection? or am I doing something wrong software wise? Please, anything. I got this thing for a reason. :p
What kind of cable did you get? What does it say on it? What software did you install? Ross Tech has 2 different pieces of software. Are you able to do a Port Test? If so, what are ALL of the results?
Registered customers of Ross Tech can get over the phone support during the work week as well.
+1 267 638 2300
My first thought / question is do you have an aftermarket radio installed?
If so look at this...
Ross-Tech: VCDS: Afterrmarket Radio Problem
What Vag-Com adapter did you by? and what interface are you using?
These questions might help us give you some answers...
Krash
KII-USB and yes, I have an aftermarket installed. I tried it with the harness disconnected and it still said the same thing.
