Well once a year I take the seats out of my NB and clean the carpet, headliner and seats. This is also an ideal time to fix that air bag/seat belt warning light issue if your NB has that problem.
DISCLAIMER: The author(s) assume that you (the reader) are reasonably capable with the automotive tools necessary to get the job accomplished, which means that you understand that a hack saw or cutting torch are not the right tools and are smart enough to know not to try to blame or post ranting about anyone else if something goes horribly wrong. AGREED?
These instructions were developed using the following NB - 1998 2.0 liter 5 speed
I'm not certain of the seat interior changes between model years, but I do know that the seats depicted here are the same from 1998 through 2000.
As always, just remember to offer a simple thank you and credit to the original author (D2Beetle) when you tell all of your NB friends!!
ITEMS NEEDED: An automotive manual; I have the eBahn Bentley DVD and the 1998/1999 Bentley Manual (C-1999).
PROJECT COST: $ 0.00 unless you break something.
SPECIAL TOOLS: T-40.
TIME NEEDED: 15 minutes for seat removal and re-installation.
SPECIAL REQUIREMENTS: The seat is heavy and bulky.
CAUTIONS: Be carefull and do not strain your back by lifting the seat incorrectly. It is not necessary to disconnect the the battery for this project; however if this is a step in a larger project you might want to. Be careful with all plastic, it will be brittle. If something does not move look for the screw(s) or clip(s) that you missed?
So let’s begin...
Step Zero: Remove the head rests as this will make it easier to lift the seat out of the car.
Step One: [VSR DIY 001] Remove the seats slide rail covers. Slide the drivers seat all the way forward and using a small flat screw driver pop off the plastic caps 1 and 2; you will need a phillips head screwdriver to get the screws out.
Step Two: [VSR DIY 002] Slide the drivers seat all the way back and disconnect the front seat mount; you will need a T-40 to get these screws out; 002-1 and 002-2. You will need needle nose pliers to get the plastic tab out; simple squeeze in the sides of the plastic tab while pushing the seat backwards.
Step Three: [VSR DIY 003, 003B and 004] Disconnect the seats wiring harness connector; there are three connectors, one is for the seat air bag, another for the seat heater and last but not least the seat belt buckle. The 003-3 connector disconnects differently than the other two, use your finger nail to push in the connectors plastic tab while gently pulling on it. A small flat head screw driver works on the other two; simply insert the screw driver under the plastic snap, twist the screw driver slightly and pull the connector.
Items 003-4 (green circles) are the wires for the seat belt connector; I put these connectors in so I could disconnect/reconnect the seat belt connector without taking the seat out. Yea, my air bag light is on and that project is low on my "To-Do" list.
Step Four: [VSR DIY 005 and 006] Disconnect the wire harness from the connector frame; squeeze the sides of the plastic clips with needle nose pliers and push down on it and it will pop out of the frame.
You are Done! Be careful when lifting the seat out of the car it is heavy.
[VSR DIY 007] shows you the bottom of the drivers seat out of the car. In case you are wondering about the bright yellow background in pic [VSR DIY 004] it is my new headliner that I put in.
So let’s begin...
