Hi, I finally got a working cable and I wanted to tweak some of the car settings.
I have a 2001 beetle.
I managed to set the remote to open both doors in one press of the button instead of two.
Anyone has more tricks? For some reason, I get no response from the instrument module number 17.
What cable did you purchase; is it a genuine Ross Tech cable? Most cables that are not genuine Ross Tech; will run a limited version of VCDS. Here is a page; that breaks down the capabilities, depending on what you are running (e.g.: VCDS Lite and VCDS full version):
http://www.ross-tech.com/vag-com/vag-functions.html
The Mark IV Volkswagens; are limited in "tweaks" compared to later models but there are some that can be done. Here are some that can get you started:
Ross tech VCDS mods for mk4 VW | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum
I got a cheap cable from amazon. It seems I'm not restricted by the cable.
I can register the app if I see some good tweaks I can run in the registered version.
Here is an example; of a full scan from my 2002 New Beetle Turbo S with a full genuine version of VCDS by Ross Tech: note which computer modules come up in the scan: in my case #17 DOES show up.
VCDS Version: Release 15.7.1 (x64) Running on Windows 8 x64
Data version: 20150904
Ross-Tech: Home
Sunday,11,October,2015,15:53:23:53097
Chassis Type: 1C (9C - VW New Beetle (1999 > 2010))
Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
VIN: (vin hidden) Mileage: 135510km-84202miles
Address 01: Engine Labels: 06A-906-032-AWP.lbl
Part No: 1C0 906 032
Component: 1.8l 5VT NB MT G 0102
Coding: 07510
Shop #: WSC 00066
VCID: 58B43D36B8DC02FE45-5120
(vin hidden) VWZ5Z0B1147047
2 Faults Found:
16716 - Knock Sensor 2 (G66)
P0332 - 35-10 - Signal too Low - Intermittent
16500 - Engine Coolant Temp. Sensor (G62)
P0116 - 35-10 - Implausible Signal - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019970
Shop #: WSC 00066 000 00000
VCID: 2E58BBEEBAD82C4EFF-5120
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 25 AIRBAG VW51 0E 0004
Coding: 12853
Shop #: WSC 00066
VCID: 22405FDEAE00982E6B-4ACE
Address 17: Instruments Labels: 1C0-920-x4x.lbl
Part No: 1C0 920 951 JX
Component: KOMBI+WEGFAHRS. M73 V02
Coding: 07232
Shop #: WSC 55723
VCID: 0004355600CC6A3E5D-4AE6
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN V022
Coding: 00006
Shop #: WSC 22503
VCID: 70E46596306C7ABEAD-4AE6
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 G
Component: 2K Komfortgerát HLO 0004
Coding: 00064
Shop #: WSC 00066
VCID: 3B7E82BA29AAC9E648-4AE6
Subsystem 1 - Part No: 1C2959802A
Component: 2K Tõrsteuer.FS KLO 0004
Subsystem 2 - Part No: 1C2959801A
Component: 2K Tõrsteuer.BF KLO 0004
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 C
Component: Heckspoiler 0002
VCID: 2B5EB2FAD9CA5966D8-51D0
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1C0 035 157 G
Component: Radio DE2 0006
Coding: 06031
Shop #: WSC 00066
VCID: 204455D6A00C8A3E7D-51B2
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End-------------------------(Elapsed Time: 04:10)--------------------------
There was a change from 2001 to 2002; the immobilizer went from Immo 2 to immo 3. That wouldn't seem to affect the ability of the module to be scanned and read. However, I do not have a 2001 New Beetle to scan and see if #17 shows up on a scan report. The only other thing I would think of is the possibility of problems with the speedo cluster or possibly a aftermarket radio, could cause problems.
http://www.ross-tech.com/vag-com/aftermarket-radio.html
